Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
thats almost the exact one i got. i got this one: https://www.lowes.com/pd/Kobalt-Kob...-x-5-3-in-Variety-Pack-Screwdriver/1000026849Maybe I got lucky but i purchased this kobalt screwdriver set.https://m.lowes.com/pd/Kobalt-18-Piece-5-in-Multi-Bit-Screwdrivers/4176915
And used it on my manix 2 s110v after the warranty update a few weeks ago. I had no trouble with loosening them. it of course took a little muscle strength but it loosened pretty easily I think. Especially since I've hear of so many people having trouble.
How to Remove Stubborn Screws from a Knife
According to the manufacturers of Loctite 263, the red Loctite used on Spyderco’s US-made knives, screws treated with it can be removed by applying heat. However, its specifications state that a temperature of more than 360 degrees Fahrenheit must be reached for it to soften. Such temperatures could easily damage the scales and other components of your knife. Instead, we recommend the following process:
1) Ensure that you have the proper size Torx® driver for your screws and that the driver head is in good condition. A single-piece, screwdriver-style driver works best.
2) Place your knife on a workbench or other hard surface. Use a paper towel or rag to protect the handle from scratches.
3) Insert the tip of the Torx driver into the screw head and ensure that it fits properly.
4) Tap the handle of the driver several times with a hammer to “shock” the screw and break the Loctite bond.
5) Maintain a firm, constant, downward pressure on the Torx driver as you rotate it to remove the screw.
6) If this method is not successful on the first try, repeat as necessary or return your knife to Spyderco with $5.00 for return shipping. We will loosen your knife’s screws upon request.
There are a few methods to releasing red loctite. spyderco recommends these steps ... https://www.spyderco.com/forumII/viewtopic.php?f=2&t=74060
some people boil the knaf, some people use hair dryer or hot air gun. others will use a soldering iron to heat up the screw.
not all spyderco's have red loctite. if you cannot easily remove the pivot or screws, dont try and torque that screwdriver as hard as you can... first resolve the resistance by trying the tips while also taking into consideration what that can do (eg, dont use a soldering iron on your scales, they will melt. dont use a heatgun or hair dryer too hot or static position that it melts your scales. etc. read the quote by spyderco, as it states 360 degrees Fahrenheit needs to be reached in order to achieve the unlocking of red loctite. again, this can cause scales to melt.
that's what spyderco said per the spec of there product. I too have had success with less heat on some of mine. others were more difficult.Totally wrong in practice. 360 degrees to completely break down the polymerized bond of red loctite, which is most certainly unnecessary for our purposes.
In practice, you need to get the screws up to about 140-160 degrees and the bond is significantly weakened. Not trying to sound like a know it all, just offering up some useful info gained through years of experience.![]()
