Stacy,
I'm not trying to be argumentative. I certainly hold you and your opinion in high esteem.
This is one of those extremely rare times I'll have to respectfully disagree.
The last time I had steel done, I got a pretty detailed tour of the facility, which involved a walkthrough from the waxing to the "stuccoing" of the trees to burn out, pouring, de-spruing, etc.
All I know about the slurry is it contains silica and the tree is dipped several times over several days into slurries of different consistencies.
I'm absolutely certain they were doing the steel the same way as their bronze because my parts were treed up and slurry-coated right next to art bronzes. Whether there were different additives in the slurry for steel vs. bronze, I don't know.
At the time, cost was the same for steel as for bronze for my little part. If it was a bigger project, the bronze would be more expensive because of the material cost (I quoted it).
I had a choice of several steel alloys including a few stainless steels, I don't remember them all, it's been a few years.
This particular foundry (the one in Oxnard, CA I mentioned) had been doing all of the steel sword hilt castings for Albion when they did my little one-of project.
I totally agree, if you're setting up with "real" (permanent) tooling, molds cost huge, huge amounts of money. Impossible to justify in most situations.
But investment casting is cheap, and it's still used extensively to cast steel and titanium aircraft parts.
If it's a part like a detailed sword pommel or other fitting, investment casting will almost always be cheaper than CNC because of the extensive programming and fixturing required before you can make even one part on the CNC. It'll be hours doing the CAD model. Then, doing compound curves requires time-intensive 3D milling (on a 3 axis) or the use of a 5th axis mill, which is big money per hour. Plus, the 5th axis guys are going to want a reasonable run to justify the more complicated programming and the time taken away from the regular (usually DOD) jobs.
BTW, if the OP is thinking of casting a blade, I'd advise against it. It's done sometimes, but it's not nearly an optimum process for that.
