- Jun 2, 2020
I noticed some old threads on bladeforums dating back to 2011 of people asking if M2 is brittle at 66 HRC. I have just made a knife out of M2 stock that is running at 65-66 HRC, made from a decent all hard power saw blade (not Bi-metal) using water coolant and grinders to remove stock.
I stabbed into hardwood and twisted the blade on its accute tip, I used pry techniques on the wood, and then went onto cutting into a round steel pipe.
The results are zero edge deformation, no chipping, no rolling, it just made the knife slightly duller, but did not disturb the apex at all.
So I thought this would be some good info to share with you all, I think people have the impression that M2 is not tough, and will break under hard use.
This knife has a slightly convexed appleseed grind that is taken back just under scandi depth. You can check out the video I recorded of the unedited demonstration here. it is 2.5mm Thick with a "Self yew" 2 tone wood handle.
