Magnetic retention sheath
I am making a sheath for a blackbird sk-5 and am planning on putting a magnet in the sheath. The magnet is the same type as used on the fluke magnetic strap holders. So its made to hold a fluke series 80 meter stationary when pull is almost parallel to the magnet. So I think it will do very good for this style of retention. My question is this: I am somewhat concerned about making this my only retention. This is my first sheath in 10+ years so most probably I am going to make a cross strap with elastic pull back on it for when I want it locked and leave it with just the magnet when I am using it frequently.
But the question here is has anyone had experience with making magnetic hold sheaths? Any suggestions? Magnet placement?
Thanks for any help!
I make most of my inverted sheaths with magnetic retention. I use the small flat magnets found under the read-write arm in old computer hard drives. Two of these are strong enough to hold a large fixed blade (such as a 7" Marine Raider Bowie) securely in the sheath, even when shaken fairly hard (as would happen if one jumped down from a fence. I embed the magnets into the back leather with 'Sho-Goo' and cover with a thin suede. I haven't found any other magnets as small and flat as these to do the job as effectively. I'll use a single magnet, often just half the magnet, for a smaller back-up boot knife such as the Gerber Guardian. These things are really, really powerful!
Stitchawl
Just be a little cautious where you locate super strong magnets (rare earth magnets) because they can really harm devices like smartphones if they come to close to them.
If you don't have a supply of dead hard drives to scavenge, I get them from Home Depot, Lowe's, Hobby Lobby and Michael's all carry various sizes of small rare earth magnets. Occasionally, you can catch them on sale.
I tried Lowe's and Home Depot, both had ceramic magnets which are not nearly as strong as "rare earth" or molybdenum magnets. The hard drives do use moly magnets but are a lesson in patience and losing a few in the process of removing them. The glue holding them in is actually stronger than the magnet, they are very (and I do mean VERY) brittle. Out of four hard drives I got three whole magnets, and there are two per hard drive.
Google is your friend when searching for molybdenum magnets, some are way over priced and some are rather reasonable.
I break them all the time when removing them. But the broken pieces are still almost as powerful, and when put together, are more than strong enough to hold a blade. The magnets aren't seen in the finished sheath so having broken pieces doing the work isn't a problem. For retention, I embed them in a layer of 'Sho-Goo,' set into a pocket in the back of the sheath, which keeps them from moving around or separating from the sheath itself. This is covered over with thin liner leather.
Stitchawl
