Maintaining with strops?
I sharpen with the Wicked Edge, Hapstone R2, Edge Pro, or freehand, depending on the knife and my mood. I have usually touched up the edges with an Idahone ceramic rod or the Sharpmaker. I recently bought a Sharpal strop to experiment with for burr-free maintenance. So far I'm not really successful. Is it realistic to expect stropping to maintain the edge? What do you all use?
Thanks,
Dave
I use a Wicked Edge. For blade maintenance a 1500 and 2200 diamond stone followed by Wicked Edge Strops using 4 micron and 2 micron emulsions.
It depends. I do use a leather strop for maintaining my kitchen knives at home. Usually a few swipes on the coarse side doped with 9 micron diamond followed by a few passes on the fine side with 0.5 micron brings the edge back nicely. Once it doesn't the knife gets a full sharpening.
Leather strops loaded w BRKT white compound or diamond emulsions for high HRC stuff.
Usually I only use diamond plates to fix damage and to reprofile the edge.
I mostly use the strop on the work sharp field sharpener. With some sort of block of green stuff.
It works fine.
Aparently the strop will work better the older it is.
I think that might be the case. But I am just kind of eyeballing it.
But my knives will go from not cutting paper to cutting paper with a strop.
I haven't found that stropping has much effect on super steels; if anything it takes away that biting edge. A few light strokes with a smooth steel seems to work better, for me at least. (I have a wood-backed paddle strop, plain leather on one side, the other with green chromium oxide compound worked in.)
I've had mixed results.on my whittle knives they only touch strops not ever a sharpener and it's the way to go. On pocket knives I seem to end up ruining the edge. Not sure why. I'm guessing I'm rolling over the edge. But why am I great with one and not the other. I suspect the lower angle of the whittle knives somehow rolls over less. But it's also very likely me. YMMV. Practice on something you care about less. It's all about consistent angle from what I hear. There is also debate over using the flat side and the rough side of the leather. Too large a rough knap can cause issues also. I son find I am way better on the cheap old strop with a thin knap. And the green compounds vary quite a bit. The greasy one seemed to work better than the hard one. Try, fail, try something else...
Yes and no.
Yes, it will bring back some sharpness but will also add to the smoothness. The more you strop to maintain the smoother the edge will become. Meaning, the edge will have no bite. It will feel sharp but not cut very well.
On the other side, it depends on how dull you let the knife get. If you can see flatness, small dings or rolls the its a big No. The strop will only work if the edge is just barely dull. Like, almost shaves but not cleanly.
Lastly, the abrasive compound you use will be a major factor. If you try using Chromium oxide on something with 4%+ Vanadium content then you would probably have the same success rate as trying to stare at it in hopes that it will get sharper.
Basic compounds are great on most carbon and stainless tools but it takes Diamond compounds for super steels.
The biggest issue with maintaining with strops is that most strops use a soft material that deflects under pressure, meaning that you have a lot of variability in your effective angle. In general you will have a cumulative ratcheting effect where harder pressure results in thicker apex angles that progressively worsen over time. Periodic resetting of the edge angle is needed to maintain cutting performance.
My preference these days is heavily biased toward a more toothy bite in my working edges--something that really only comes from a coarse or medium grit stone.
Years ago, I used to rely more on a strop with compound when I was doing more polishing of my edges. But if the desire is to maintain a toothy bite, then that'll only diminish with prolonged stropping. The edge will always become more polished and less aggressive in slicing cuts, if nothing but a strop is used to maintain it. I also tend to believe that even if one is careful to avoid the rounding effect from a soft substrate like leather or fabric on a strop, the edge will still get too drawn out and too thin on a strop to be durable for anything much more than shaving hairs.
I like the fine balance between slicing aggression and edge durability that careful edge-leading finishing on a medium grit stone provides. Any stropping I might do beyond that is always very, very minimal and is done using no compound at all. Just basically enough to remove any loose, weak remnants of sharpening from the apex and no more.
My preference these days is heavily biased toward a more toothy bite in my working edges - something that really only comes from a coarse or medium grit stone.
It may have been both you and Cliff Stamp who put those ideas in my head, and I have been very happy ever since. I love the edges I get off a medium or coarse stone/plate. Saves time and I don’t fuss with strops anymore. I’ll use a piece of cardboard if need be.
I mostly use strops for intermittent light touchups or for assisting the deburring process on freshly set edges where a wire edge has formed, and in those circumstances I prefer to use a piece of solid wood since it has less deflection than leather or fabric, but I usually just finish the edge with light edge-leading strokes on a stone.
Agreed about leather strops taking away the bite, but denim strops seem to be an exception to that.
This about that… I mechanically sharpen and strop.
I can maintain quality kitchen knives, like a Shun, for a very, very long time if I don’t let them get dull… like months before the knife needs to be re-ground. While it’s true that stropping smooths out the teeth, if you maintain stropping at the exact angle sharpened or even very slightly less, your knife should stay sharp as measured by a BESS. That’s to say, if I sharpen to 100 on the BESS, I should be able to strop it back to 100. If the edge has been lightly used. So, the act of stropping does not dull a knife, only poor technique.
Kitchen knives perform perfectly without teeth if the edge is maintained at near 100 on the BESS.
As far as what paste is most aggressive? I haven’t tried a lot but I do agree that AO paste is generally more aggressive than diamond paste. Diamonds are great for refining, polishing and supersteels. (After repeated stroppings you will notice the carbides standing tall even with diamonds on some steels with a strong microscope). If you use diamonds for cutting make sure they’re polycrystalline. Monocrystalline are more effective at polishing. The polycrystalline made a big difference in testing, much more effective at removing material.
Just me- I seldom use a strop for
anything other than a razor.
As long as I can remember I've been
able to get a satisfactory edge with
a carborundum or Arkansas natural
stone either one, and using either a
regular grooved steel or ceramic rod
if I'm processing fish or game,
or needing to cut up a lot of vegetables
or something.
Some knives will respond to a stropping
and some aren't any noticeably better.
If I'm in the midst of breaking down
a deer or something, I can get half a
dozen licks on a steel and jump right
back in to work way faster than I can
diddle with a strop, having to clean the
knife and my hands of blood, etc.
or something.
Steels most definitely will put some type of edge on your knives. After steeling with one that has grooves look at it with a microscope. Not pretty... I prefer the smooth steels. They work the same, they just don't tear up the edge so much.
Some steels are just harder to get and maintain an edge, like cheap stainless knives.
It's best to think of grooved steels as being like a fine file with the teeth running perpendicular to the long axis.
I use a strop for touch ups if needed and to deburr between diamond grits. I use a 14 micron on the rough side and 3 micron on the smooth side in a diamond emulsion usually. I also have a 40 micron/1 micron setup as well I have been playing with. My favorite waterstones are a Bester 1200 and Rika 5K, so I tried to replicate that in a strop. Bare rough side leather after the Rika 5K gave a nice sticky sharp edge on my kitchen knives. I wanted courser grits for the strop to try to keep the toothy feel and be able to be used for minor chip removal/repair as well.
I took the 14/3 strop and an AEB-L blade at 60 HRC with a visibly flattened edge with some tiny chips and stropped it back to shaving arm hair in a few minutes. Low pressure and letting the diamonds do their work is the key so the leather doesn't round the edge too much. It gives a decent convex edge if that is what you are looking for over time with more pressure, but the toothy and bitey feeling does go away.
I took a Magnacut kitchen knife (64 HRC) that was starting to get dull (wouldn't slice well across a Bounty paper towel held vertically, kinda tore it instead of slicing it) and with the 1 micron side of the 40/1 strop, 2 strokes on each side of the blade and it was back to sharp again, cleanly slicing paper towels horizontally a good bit into the paper towel when before, it wasn't cutting well and mostly tearing. I typically don't let the knives I use get dull and touch up on the finest side of the strop and can maintain a nice edge for the kitchen with the strop for a long time. With Japanese kitchen knives, the 14/3 will remove micro chipping and bring back a sticky sharp feeling edge in most of the steels they use (White, Blue, Aogami Super, VG-10, R2), but I haven't tried it with HAP40 or ZDP189 (don't have anything in those steels).
The 40 micron didn't leave a super toothy edge like I was expecting it to. I was kinda hoping it would be a way to keep the tooth a bit more, but it works fast and removes the toothiness pretty quickly. Nice for removing micro chips though, or reprofiling to a convex edge! I use my Sharpal 325/1200 and the best edges I seem to get are using the 1 micron side to deburr after the 1200 side. A few strokes, no pressure, is all it takes and it leaves a bit of tooth left to the edge. Feels similar to the off the stone Rika 5K/bare leather strop edge and feels nice and aggressive. Going with a diamond compound on the strop lets you use no pressure and still cut the super steels. I want to try some homemade micarta pieces and using the diamond compounds on those; they are softer than commercial micarta and will have a fuzzier feel at lower grits, so it will be similar to leather rough side, but hard and won't round out the edge as much.
