- Aug 28, 2010
Just found this article (apologies if it's already been posted).
Make Your Own Axe Handle, by Russ Morgan
Northern Woodlands magazine
Some highlights:
- The woodworking is done while the wood is freshly cut and not "seasoned"
- "All you need is an axe, a drawknife, a spoke shave, a rasp, and a sharp knife with a flat bevel."
- A low-cost mixture of white glue and hot water is used to seal the ends while the handle is drying
(I previously saw this mentioned in the Foxfire books).
- a slim 3/4" handle thickness is suggested.
- "The one guiding principle to keep in mind when making an axe handle is to keep the same annual growth ring in the center of the entire handle, from where it will enter the axe head to the fawn’s foot. That annual ring will be split by the wedge in the final step..."
http://northernwoodlands.org/knots_and_bolts/make-your-own-axe-handle
Some highlights:
