It won't help with the action... Teflon actually has a lower coefficient of friction than pb. If you want it to flip good you will need to do some detent work.I discovered this thread this past Thursday night, as I'm looking to rehabilitate an older XM-18 3" model that doesn't flip well at all. I gotta believe that replacing the teflon will help some. Anyway, I've ordered the 1/4" x 1/2" x .015th PB washers from USA Knife Maker, and if they don't fit on the lock side, I'll just work one down with a Dremel, or simply use a diamond stone. It's a cheap enough experiment that I won't feel too bad either way, and it's a good way to pass an evening.
I got them at USA Knife Maker. The size you need is 1/4"ID x 1/2"OD x .015"Th.
Do you know what size washers the Hinderer Jurassic takes? I know the two washers are different sizes.
I enjoyed reading through this thread. Thanks for sharing. I, too, have polished PB washers in my hinderer XM-18 Skinner. I like the feel of them a little better. I'm about to take it a notch farther though. I'm going to put multiple washers on each side (thinner ones, of course). Many of the G-10 Spyderco's that I've disassembled have had multiples on each side of the blade. They are all as smooth as butter. I'm curious to see if it will affect it at all.
I used the dimensions given above on both sides when I had a Jurassic and they fit just fine.
What do you mean by detent work? Bending the lockbar in (towards the blade) or out (away from the blade)?
