Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
I use some strong thread when I make my keychains and thought I'd try putting some of that along the start of my power cord for my iphone, so the area just before the connector is less prone to bending and can help prevent damage to those fine wires that are connected at that point. It would also be good for the android cables to I would imagine.
I use what is called a whipping knot, basically make a loop, then wrap the thread tightly around until you reach the end.
Then I pull on the one part of the exposed loop so it cinches up the start of the wrap, making it quite tight there.
Then I slip the one end through the loop and pull the loop down and under the wrap. Take a small pair of scissors to trim off the end and pull the end beneath the wrap.
Then trim off the part at the start of the wrap and you're done.
Here are some images to help;
Untitled by GaryWGraley, on Flickr
I have also seen where people have used some heavy shrink tubing to accomplish the same thing, but, I don't have any of that stuff, now this doesn't stop someone from bending it 90 degrees but it will help keep the end straighter when charging and you are handling the device at the same time.
G2
G2
