So I basically had no idea what this stuff is until recently. My understanding was, some type of synthetic wood for scales. The other day however I seen a thread where a guy made a block of the stuff out of an old colorful quilt or something, which confused the hell out of me. So I looked it up, and it turns out it's just fabric, soaked and hardened in resin, basically, right?
Watched a couple tutorials on youtube, and it looks very easy, something I plan to try after the new year instead of breaking apart old desks and dressers for hardwood.
There were a couple different processes I seen, layering and such. The one I would like to try though, the guy basically cut a bunch of 1 inch strips of different colored (camo) cloth, mixed it in a cup of resin for a few minutes. Put it in a plastic bag, secured it so it wouldn't seep out anywhere, and then clamped it down. He showed some knives made with this material, and it was impressive.
Is it really this easy? As a guy who didn't know what micarta was until a couple days ago, do you think I can make set of decent scales?
I plan to do this at the shop at work. For fabric, we get these 20lb bundles of cut up tshirts to use as rags, large variety of colors but mostly seems to be the same fabric, with a few exceptions. I had planned to use this, do you see any problems using old tshirts as a base for the material?
In all three videos I watched, none of them mentioned how long I should leave it clamped to harden the resin enough, can somebody enlighten me please? 10 minutes? An hour? Over night?
I plan to use that "bondo" fiberglass resin, I assume homedepot would carry this product? Is there a particular product name I should look for? I also understand it is rather nasty. I do not have a proper respirator, those paper ones with the elastics to attach to your face is the best I got, I don't see that helping with fumes. However, in our welding bay, we have a powerful ventilation hood. 10 square inches for the vacuum end, it will reach out 20 feet into any position. It has enough suction to suck up 90% of sawdust off the table from 12 inches above and it simply sucks it all outside and vents it behind the shop. Made for fumes, welding smoke, and grinding particles. I figure if I keep this over my work the whole time, while keeping my head a little ways away, the fumes shouldn't be a problem. Do you see a flaw in this?
Assuming I create a workable piece of the stuff, I know grinding and sanding is even worse then the fumes. Would using this vent hood, as close to the grinding as possible, along with a paper dust mask be sufficient protection?
A lot of questions, I know, thats why I come to the pro's. Any other tips you guys can throw my way to help me make some of this stuff? With all the possibility's for colors and patterns and experimentation it seems like an excellent handle material, I just have the few concerns I mentioned.
Cheers guys, have a Merry Christmas.
