That would be "Dumbass-cus"There where some people selling “Damascus” “pattern welded” steel awhile ago that where basickly just drawing on the steel with the welder. Not any particular patterns just random lines and stuff.
Though still 'pattern welded' syntactically.That would be "Dumbass-cus"
I'm trying to figure out how to do this .I would like stainless to remain quite deep in bevel .I mean as close to edge as I can.....something like this.....even more close if I can do that ? Obviously I must first grind bevels deep enough . Hey, can I do hamon too if I use 1095 ? Anyway I think that first I will try on narrow piece of steel for Puukko blade .The grinding angles are bigger so there is no problem to stay more SS steel on bevel .I'm interested to see how it looks before and after HT once it is ground/milled flat.
I would really appreciate your opinion about this , JTknivesThere where some people selling “Damascus” “pattern welded” steel awhile ago that where basickly just drawing on the steel with the welder. Not any particular patterns just random lines and stuff.
Torch................ it is not recommended to use gas for preheat steel for welding , at least I remember that way ?Just use a torch. Get it up as hot as practical. The big point of a preheat when welding steel with a lot of carbon is to slow the cooling curve of the puddle, keeping stress low and possibly preventing martensitic transformation (though with all the chrome in the SS filler, your puddle will have haigh hardenability). Preheats for this sort of thing don't have to be all that precise.
I was planned to use refractory brick under steel to keep heat on steel ? What do you think about that ?Just use a torch. Get it up as hot as practical. The big point of a preheat when welding steel with a lot of carbon is to slow the cooling curve of the puddle, keeping stress low and possibly preventing martensitic transformation (though with all the chrome in the SS filler, your puddle will have haigh hardenability). Preheats for this sort of thing don't have to be all that precise.
I would. Use a welder’s third hand to ground the peice. You may get extra distortion from heat build up because of the brick.I was planned to use refractory brick under steel to keep heat on steel ? What do you think about that ?
I would encourage it, but you don't need AC for this application. Check out Everlast and AHP for reasonable prices. I would avoid the new domestics from a cost/performance/warranty standpoint right now.Nice. Now I have a reason to pick up an AC/DC tig!
