- Apr 18, 2017
I got a M2 lw last week and I already have 2 G10 models. The lightweight model was very stiff. So I lubed it and loosened the pivot and flicked it a lot. Now it is still stiff unless I loosen the pivot screws to where it barely touches the pivot (no blade play) even with both screws removed there is no blade play.
I searched if there were others with this problem and many said it will break in and not to loosen the screws too much. So my question is why can't the screws be pretty loose (with loctite) if the action is good then? Why should I tighten it and wait for it to break in and be smooth if I can just loosen the screws. I must add though that the screws has to just touch the steel washer of the pivot otherwise the action is stiff. Thanks for any advice
