I make folders primarily. I am constantly marking, normally with a Sharpie or some such. But these pens work only on clean steel..ie..no oil or grease, no water. Heat erases it, etc. Is there an alternative other than Dykem, which works for initail layout, but a pain to constantly repaint. I assemble the folder, check tolerances, mark, grind, assemble, check, mark, grind, etc. This happens many, many times for one folder. Leave the top off a Sharpie for ten minutes and you have to reactivate with thinner. What else is there? Thanks.
