BD_01
Basic Member
- Jun 9, 2016
My review of the Crux is long overdue. That’s a good thing, as a month of fairly consistent EDC has helped solidify my impressions.
For the TL,DR crowd, skip to the SUMMARY section for a synopsis. Of course this review is subjective, YMMV based on personal taste. I welcome your commentary and discussion.
DESIGN: Excellent.
The design did it for me from the first picture I saw. The size, blade shape, and aesthetic is nearly ideal for my EDC preference. I like understatement. The blade to handle ratio is good. Some have commented on the unusual shape of the blade’s sharpening/finger choil. Personally, I like it as it takes an arc nearly identical to the lockbar access cutout.
Size is between a small and large Sebenza 21.
ACTION: Excellent.
Out of the box it was just OK, so I took it apart, cleaned & oiled, and ‘bam’ great action. My guess is the factory lube was a bit viscous and gummy. Disassembly was easy—except there was LocTite on the clip screws! Reassembly was predictable. Tighten the pivot until centered and stop. Perfect.
FIT: Good.
Everything is fine, but there is nothing amazing either. It arrived a bit off center, but the pivot (no LocTite!) just needed a bit of adjustment. No lock stick or other real complaints.
FINISH: Needs Improvement.
Herein lies one of my two major gripes about the Crux. While the outer edges of the scales are nicely chamfered, the inner edges are a bit too abrupt. This is especially true on the lockbar. Lockbar tension is fairly strong and thumb access a bit tight. One has to jam their thumb fairly firmly for access, and ramming into an abrupt corner is not real pleasant—especially for repeated cycling. A chamfer is desperately needed here. A few thousandth more cutout on the show scale would help too.
Less of an issue is the overly fine the bead-blast finish. It scratches super easily. That doesn’t upset me too much; the weathered look will be cool. However, a stronger blasting would hold up better and feel less ‘chalky’ in the hand.
Good points about the finish include jimping on the flipper tab that’s just about perfect and an even (albeit plain) satin on the blade.
