sph3ric pyramid said:The William Henry lineup with the damascus/ZDP-189 laminate look incredible, but they cost about the same as a decorated large Sebenza or as much as some of the full size custom folders out there.
There wouldn't be much point in putting a material like that in a riveted Zytel handle, so I'm assuming that, less the semi-production status of the WHs, any knife made with the material is still going to be pretty expensive.
It is a stainless damascus laminate.The Deacon said:The Mcusta knives use a VG10 core laminated between damascus outer layers. Am not entirely sure if the damascus is even stainless. In any event, finding a source of ZDP-189 core damascus blade stock is very unlikely.
The fact appears to be that, at the present time, only two outer steels are offered, plus solid ZDP-189. Unless you are suggesting Spdyderco find someone to custom make a ZDP/stainless damascus laminate for them (which I am guessing would be very expensive), or use the VG10/damascus laminate instead of the ZDP-189 ATS-134 or 420 laminates, which would go against a major component of the project being planned.
Ok Larrin, I was not sure. Perhaps I am misreading the original post, but it looks to me as if Danny is suggesting the VG-10 damascus laminate as a substiute for ZDP-189 in the Lum Chinese project and possibly even the Delica sprint run. Since at least one of the purposes of those runs is as a testbed for ZDP-189, I don't think it would work out.Larrin said:It is a stainless damascus laminate.
freddy1 said:i'll suggest to also do the handle in stainless damascus...
That woudl make the nicest Lum Chinese ever made !![]()
