Meadowlark PE: Chisle?
Well, I looked at a bunch of knives in the store the other day, including a Meadowlark with combo edge in G-10. I've heard some of the byrds with combo edges come with a full chisle grind (on the serrations as well as the fine edge). Don't recall if the meadowlark combo had chisle or not, but anyways, I kinda want to make sure a plain edged Meadowlark is a full double bevel? Pretty set on getting the g-10 PE meadowlark, thanks!
I've never seen one, but my PE Flight is normal double bevel grind. I'm sure the only thing you will find the chisel grind on is the combo edge.
the closest example I can think of is the serrated c 25 which had about half an inch of chisel grind at the end of it serrations I think the chisel grind meshes better with the serrations and makes for an interesting change
