I'm just curious what my edge angles are and want a really accurate way of measuring them so that I can familiarize myself with how a knife performs at various angles, and be accurate. Right now the best way I have is to using my calipers and do some math stuff, but I wonder how accurate it is. I've tested it on some stock production knives by calculating how high I think I need to hold the spine to match the factory grind, and it's close, but I can't tell how much error is in my measurement, in how well I'm setting it on the guide I set up, or how well I hold the angle. It seems dead on though.
Anyway, I figure that a laser pointer would never be as accurate as the CARTA thing, but I wonder if it would be more accurate than using calipers. I figure that if I used something like a 5 gallon bucket and cut the bottom off so it's kind of a tray, I could mark out the degrees on the walls of it and use those little "divots" that are in the center of them to line the laser pointer and blade up, but who knows if that would be accurate enough. There's nothing saying that the light in the laser is mounted square.
Not that I need to be really accurate or precise, I just can't really see my edge very well because it's so thin, and it'd be nice to tell what the actual edge angle is . Using calipers is fairly accurate from what I can tell, but a laser goninometer would be better... I'm just not sure doing it with a laser pointer and what not is any more accurate than using calipers. Anyone know how much the one from CARTA is? May be a worthwhile investment since I want to get into making knives, and I'll need to test different edge angles.
How do people here measure edge angles? I saw one user using JB weld on the edges, and that looks like something that would be nice to use, and maybe possible to measure with a good machinist's protractor, but this is the most expensive option outside getting the CARTA machine.
