Meat Cleavers
Antiquety? if a meat cleaver is old and bad shape rusty and nicked up, how much restoration should and should not be done?
Is it a rare and/or valuable old meat cleaver? If yes, besides using mineral oil, I'd leave it alone. Otherwise, restore it however and as much as you want to.
Now that was an easy answer? So which is it? do I take them apart, anneal them, grind, polish and harden back up. Then deep line etch art into them meat cleavers, finally put a righteous handle on them. Or do I lightly steel wool it to death, and linseed oil the handle, and hide them from my view, since it still the original boring old knife, but it has great nostalgia?
break out the bedazzler:D
Are you a maker?
I say if it's valuable to you (only) do whatever you want to it. Make it truly yours, then post pics!
I love cleavers!
To make an assessment regarding restoration I'd need to see a photo.
What ever you do enjoy it and try not to use it. I got my hands on an old meat cleaver stamped, Case XX. I got the blade looking mostly good and used mineral oil on the old oak handle. After it layed around for 5mos. then winter came and I needed to simply split some slivers of oak off a 1" thick slab for kindling. So, looking around, I grabbed that cleaver and after the second hit I heard something bounce on the floor. Looking around I found it, a dime size piece of metal had split out of my old cleaver and ruined it for original value. DM
Depends on what you plan to do with the cleaver. If you want to use it, definitely get the rust off. If it's heavy surface rust, a little sandpaper will do the trick. If it's light/spotty surface rust, I'd use metal polish (I prefer Wenol). Then give it a good edge, which in the case of bad nicks will mean a good reprofile. A rub down with mineral oil, and she's good as new.
I'd say mod it to your liking.
I did this old Village Blacksmith not long ago.
I cut it down to a profile that is pleasing to my eye,lightly polished with scotch-brite & 400 grit,gave it a convex edge and blued it with some Birchwood Casey Super Blue,then replaced the old handle that was cracked & missing chunks with some pallet Oak.
For this Case's Tested I just replaced the badly cracked handle with some more pallet Oak,hit it with some 000 scotch-brite & gave it a good convex edge.
I reamed the handle rivet holes out to 1/4" on both pieces also.
