scdub
Basic Member
- May 29, 2004
Hi All,
Just wanted to alert you fine folks to a device that I think is pretty nifty.
It’s called the “Meater” and it’s a WiFi thermometer that’s used to cook more accurately - primarily meats.
I’m not usually a fan of high-tech kitchen gadgets, but my buddy got me one - specifically the “Meater Plus” - for Christmas last year and I’ve done quite a bit of cooking with it so far.
It’s essentially a fancy thermometer, but you insert it into a piece of meat before cooking, then leave it in while the meat is cooking at a low oven temp (~250F).
It reads both the internal temperature of the meat as well as the oven temperature, and this allows the Meater app on your your phone to calculate the time until it will be up to temperature. It alerts you when it’s at your target temperature (you can set this or just use the suggested temp), and then you remove the meat, let it rest for a couple of minutes, remove the thermometer, then “reverse sear” in a pan or on the grill.
It’s been essentially 100% so far and I’ve been very impressed. I’m much more comfortable now buying nicer cuts of meat because I’m confident I won’t screw them up.
Anyway I’m not affiliated or anything, it’s just been a good product for me.
Anyone else using one of these?
How do you like it?
How do you like it?
