take that you bastard!
Titanium kukri?
Just dreaming...
funny you should say that; I was running my 555 with a brand new X-Cut chain and took it into a rock and that was that. Those chains are a bastard to sharpen so I put it aside, got the chipper fired up and machete'd all the stuff going into the chipperYou know in Canada they have this thing called a chainsaw. It's like a bunch of little titanium swords on a steel rope that goes around in a circle and chops up trees real quick. HAHA!
Nice work on that little ti billet! You got to see how crude they are before being turned into a blade. That alloy is really great, don't you think? What do you think?
there was a fair amount, not a ton, of stuff that got cut with this blade. I never did get quite the edge on it I wanted before putting it to work, since the burr is so tough to remove. The edge is actually slightly better than when I started in that I think I smashed the burr off finally. The flexibility was a concern of mine from the beginning, but so long as I avoid glancing blows it's not a problem in the least, and likely of benefit. I like that I can work it hard and put it away wet
there are pumpkins need murdered, and I'd like to figure out a way to film a cut which shows the blade flexing through it...
Idk if Mine, from David Mary flexes much? Not sure if they are the same size or same batch of materials as this one?One of my favorite ways to remove the burr is to slice up a thick piece of leather several times. Most everyone agrees that these ti machetes seem to get better and better with use, anyway.
If you can impart a slight distal thickness taper into the blade (assuming you didn't already) it will reduce flexy floppiness and impart some extra stiffness, and help control the shock of any glancing blows. I know the billet is so thin and light already though, might want to just retain the extra grams.
I think I felt a couple "twinges" from really hard hits. That might of been some shock absorbtion, perhaps....... But the log i chopped in half was Maple. So it was probably more intense.
I'll try some leather, and keep everyone posted how this blade preforms. So far I've had two sessions, and maybe more chopping tonight....ha
I'm really pleased with the blade geometry, I definitely won't be changing anything. I would like to make another one though
just to be clear; the flexibility was a concern I had before making and then using this thin material. Now that I've had a couple short sessions to become acquainted with it, I regard those concerns as unfounded.
The blade feels very natural, with the balance point pretty much in the ricasso area. The swedge removed somewhere in the range of .3- .4oz and judging strictly by feel, that was the right move.
I might know a guy who could give you pointersI don't know if I'd do anything significantly different,
I'd like to anodize it
I don't know if I'd do anything significantly different, just better. Did a bunch of things I never did before on this and now I've done it once I can make improvements
