RE: "Mechanical Difference Between Assisted Openers and OTF from a Legal Perspective"
Where I live:
Blade vs. Any Other activation method of opening of a spring loaded knife with a bias towards being closed in a neutral state.
Blade Opening Activation - would include touching the blade, blade-tang, blade-stud, blade-disk, blade-flipper-tab, etc.
vs.
Any Other Opening Activation - would include touching a button, bolster, etc.
Other jurisdictions may vary on specifics.
Would recommend researching specific regional municipality codes.
** Code example text below in my regional municipalities classify "spring blade knife" as a "Dangerous weapon" and are prohibited carry except under specific circumstance (example: on duty LEO). Last half of last sentence was adopted in my state a few years back to specifically allow "Assisted Openers".
"Spring blade knife" means any knife, including a prototype, model, or other sample, with a blade that is automatically released by a spring mechanism or other mechanical device, or any knife having a blade which opens, or falls, or is ejected into position by the force of gravity, or by an outward, downward, or centrifugal thrust or movement. A knife that contains a spring, detent, or other mechanism designed to create a bias toward closure of the blade and that requires physical exertion applied to the blade by hand, wrist, or arm to overcome the bias toward closure to assist in opening the knife is not a spring blade knife.
** United States Code
U.S.C. 15 CHAPTER 29 - MANUFACTURE, TRANSPORTATION, OR DISTRIBUTION OF SWITCHBLADE KNIVES
§1241. Definitions
As used in this chapter—
(a) The term “interstate commerce” means commerce between any State, Territory, possession of the United States, or the District of Columbia, and any place outside thereof.
(b) The term “switchblade knife” means any knife having a blade which opens automatically—
(1) by hand pressure applied to a button or other device in the handle of the knife, or
(2) by operation of inertia, gravity, or both.
