How much wider?
Suppose to be the same thickness .25 as the BC-Interesting.
I agree, would guess it is .25 thick, however the wider blade has me intrigued (in a good way)Looks like an optical illusion upon closer scrutiny! It has lighter colored liners and also because the camera is centered atop it
Don't forget that Nathan had done some re-thinking on that original HC which was supposedly unbreakable and then applied similar but perhaps just a tad less indestructibility traits to the HDMC in order to bring this into the fold with his more modern patterns like BC & the MC. So yup, it may be a bit wider just like how you'd like itBad, bad Matty!
I have forgotten as to what Nathan had blurted out once, like one was for knuckleheads and the other for: <insert here>
Are you remembering this line from the pre-order?:
"you can order a Heavy Duty Medium Chopper here. It's a thicker version with thicker stock (.250"), taller grinds, smaller fuller and more meat left behind the edge for you knuckle dragging meat heads who break shit." - Nathan Carothers
Definitely going to be a special blade! I’m very glad I was able to get in on one.Nice set. I agree it looks thicker.
Could you also take a pic of the blades all together? Showing the MC vs the HDMC please.
The HDMC looks like quite a special blade.
Thank you!
HDMC on the bottom MC on top.
HDMC on top and MC on the bottom.
It’s .275 I think and it’s a big boy
The MC is .220, the HC will be .250 or .260, like the original
Jo also mentioned that the sheaths are not really compatible due to the thickness difference.
It is a full .275 at the spine.
.275 at the spine? Nice, the HDMC may actually "Bite" a little deeper than the BCThe production Heavy Chopper (HDMC) is indeed still incredibly stout and indestructible (I'm borrowing a page out of Jerry's book here), but we gave it a narrower and therefore taller grind than the original Heavy Chopper so that it would have better cutting performance. But the weight and indestructible character is all still there. It is a full .275 at the spine.
The standard Medium Chopper is lighter with thinner grinds and is probably a more reasonable better balanced knife but if you want something very stout the HDMC will deliver.
EDIT: I would assume the HDMC would also weigh slightly more than the advertised weight of 23.2 ounces?
Thanks for the weights, Looks like Nathan continues to work his Magic. I would have thought it weighed more (shrug) What the Hell do I KnowHDMC:
MC:
