- Sep 30, 2005
I am a big fan of Flitz metal polish.
I know many believe it has no abrasives whatsoever (removing no metal), but it does to an extrememly miniscule amount.
To test this, one can put a small amount on a soft cloth, and with a decent amount of force, rub a piece of brass for a bit (one will notice some of the goldish brass on the cloth).
While at the local Sears Hardware store yesterday, I noticed some Noxon metal polish. I had not had any of this stuff for probably 15 years, so I decided to pick some up.
I know it used to work great for me, but somewhere along the line, I started using Flitz as a general metal maintenance and final metal polish, and I was hooked.
I had forgotten the level of performance that Noxon offered, so I had to re-introduce myself to Noxon.
The first thing I did when I got home, was to do a few comparison tests of these two polishes (a head to head, so to speak).
The Noxon is a creamy colored water based cream polish, where the Flitz is a greasy and bit thicker creamy polish (thicker as in being closer to a paste).
I first tried the Noxon on a piece of brass, and after quite a bit of rubbing, only found a miniscule amount of brass on the cloth (I mean almost nothing).
I did the same thing with Flitz, and the cloth showed more brass for sure.
The sheen is about identical, with I believe the Noxon having I tiny edge over the Flitz.
My conclusion:
It seems that the Flitz, while extremely mild, does a miniscule amount of abrasive work to achieve it's high shine on metal surfaces.
The Noxon, it too seems to do this, but even at a finer level (which was hard to believe, with the Flitz already being so fine).
Which is better?............. depends on what one wants it for.
They are both great, IMO.
If I were comparing it in wood and sandpaper terms,......... it's like if the Flitz were to have been a 320 grit, then the Noxon would have been like a 420, (with both having their more appropriate purposes, but can also overlap in performing some of the same work).
I "may" now use the Noxon as my General maintenance polish (to polish things that already have a high polish that I'm happy with), while probably keeping my beloved Flitz as my final metal polish on items that I'm working a high polish onto.
Overall, I'm glad that I've added Noxon to my list of polishes again
My conclusion:
