I generally use slow drying epoxy to attach scales to my full tang handles but am teaching a class in the next couple of months and, due to the schedule, we do not have the time to let the knives sit overnight before shaping the handles. I can only let them sit for a maximum of 1 hour. It seems that Loctite 324 with the activator is my best bet. Since I've never used it before, Id like to get some strategy advice from those with experience with the product. Im thinking the best way to go about attaching the handle would be to apply the 324 adhesive to each scale, then slide the brass pins through the metal and set each scale on the pins but leaving a gap between the metal and wood. Then spray the activator through the gap on each side and quickly clamp it all together. This way there would be no fumbling with the pins, worry about getting them set and clamped before its too late. Does this sound like a good strategy for those who have used the loctite adhesive? If not, what would you recommend? Also, will the activator negatively affect the outside of the wood in any way? Using this method would obviously get a bit of the activator on the outside of the scales. Hopefully it sands off and doesn't discolor the wood below the surface. Any helpful advice would be much appreciated!
