Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
They're the same thing.what is the diffence between these, and what are there functions/ purposes
can i use the word "differeter" here?For example, J. Doyle has just indicated that he is referring strictly to edge bevels. Because if he was considering the blade's primary bevel starting at the spine, then he would have called the microbevel a tertiary bevel.
I find that convention of designating bevels a bit more confusing, personally, because every facet on the blade is, strictly speaking, a bevel, so for clarity, if I were referring to the edge bevel as the primary bevel and the microbevel as the secondary bevel, I would call the primary bevel, the primary edge bevel.
No, sorry, but I wouldn't ever use the word "tertiary" in reference to a knife.For example, J. Doyle has just indicated that he is referring strictly to edge bevels. Because if he was considering the blade's primary bevel starting at the spine, then he would have called the microbevel a tertiary bevel.
I think it's less complicated to not add any additional bevel to the cutting edge.When someone says primary, secondary etc., it means they are counting the number of something, in this case bevels. It doesn’t make sense to me to call two separate bevels both secondary.
But you think it is less complicated to call both the cutting edge and the microbevel "secondary" even though they are different bevels, go right ahead. I don’t accept the implication it’s the one and only correct way, though.
If you're doing more than that, you're overcomplicating knifemaking
