Microwear L5 Smartwatch Has All The Things It Should Have
Feedback: +0 / =0 / -0
The Microwear L5 smartwatch comes with a round shape, which is classic and sporty as well. It has diamond carbon coating body with a silicone strap and 1.3 inch TFT display, 240 × 240 screen resolution with touch screen supports. The Microwear L5 is a IP68 waterproof smartwatch, that means you can you use it when you wash your hand or getting wet in the rain, and also it is suitable for swimming. It's also equipped with health and sports features, like heart rate monitor, pedometer, sedentary reminder, sleep monitor, drinking reminder.
Product Features:
● Clear Display
1.3 inch TFT full touch screen with 240 × 240 high-resolution, great viewing angles up to 178 degrees. The screen is covered with a beautiful 5D glass that looks rare and gorgeous.
● Raise Hand to Wake Up the Screen
Equipped with a 3-axis G-motion sensor, you can raise the hand to see the time, the screen will be automatically awoken.
● Heart Rate Monitor
Give you the real-time feedback, let you know about your heart rate anytime and anywhere.
● Oxygenation Measuring
With the function of measuring the oxygenation of blood o2, fitted with two diode heart rate monitors with green light to make the measurement even more accurate.
● Display Health Parameters
Display the time, date, steps, distance and calories clearly, let you know your sports data immediately.
● Sedentary and Drinking Remind
When you are sitting for a longer time than the preset duration, the watch will remind you with vibration or a ring that it's time for exercise and drinking.
● Alarm Remind
Setting the alarm clock on the phone, the watch will remind you with vibration.
● Multiple Sports Mode
As many as 9 sport modes: walking, running, cycling, mountain climbing/trekking, swimming, football, basketball, table tennis, badminton and finally activity history.
● Calories Consumption
Master your exercise and calories consumption at any time and anywhere, monitoring your raining status at any time.
● Sleep Monitor
Knows when you go to sleep and when you get up, you can check how long the deep and shallow sleep lasted.
● Remote Camera
Control your smart phone to take phones on your wrist.
● LED Lighting
The only such smartwatch on the market with LED flashlight, you can activate it with a dedicated button below the flashlight, there is also an emergency alert flash.
● Anti-lost
When it's synchronized with your phone, the watch gives an alarm by beeping when the phone is more than 10m away from it.
● Calls/Notifications Reminder
When someone sends you a message, you will be notified about this vibrating signal. SMS notifications as well as from social applications, the beginning of the message can be read on the screen. When someone rings, the watch lights up and vibrates, you'll be able to see who's calling.
● Increditable Battery Life
Nordic battery management chipset gives 380mAh battery capacity, which can last 100 days in standby mode, working time is up to 7 days.
● IP68 Water Resistance
Use the watch in everyday activities, for example when washing hands or on a rainy day, without worrying that water will get inside.
The Microwear L5 is a good smartwatch, you won't find another smartwatch with so many features at this price: https://gearvita.com/microwear-l5-smartwatch.html
Related products:
buy huami amazfit 2 stratos
buy huami amazfit verge smartwatch
Edifier W2 wireless earphones use true wireless technology, wireless interconnection of left and right ears. A new generation of true wireless stereo, binaural calls, left and right ear split design, also can be used alone, easy and convenient.
Product Features:
● Mini But Strong
The shape is smaller and more comfortable than most TWS headphones.
● One-button Operation
Both sides of the headset have multi-function buttons for call and music operation. Both sides of the headset have a omnidirectional microphone port to support noise reduction in the voice call environment, and the call is convenient and clear.
● Special Design
When the earphone is taken out from the charging box, the power is turned on, the left and right earphones are interconnected, and the connected device is automatically connected back, which saves time and worry.
● Bluetooth 5.0
Bluetooth technology upgrade, faster transmission speed, lower power consumption, more than 10 meters of barrier-free transmission distance.
● 12 Hours of Battery Life
The texture charging box, the magnetic card slot, absorbs the stability. The headset lasts for 3 hours, the charging box can be recharged 3 times, that is, an additional 9 hours of battery life, to ensure that every trip is uninterrupted.
● IPX4 Waterproof
Effectively prevent rain and sweat from damaging components.
Edifier W2 is suitable for users who need quality and freedom of movement while listening to their favorite songs: https://gearvita.com/edifier-w2-wireless-stereo-earphones.html
You may also like:
cheap xiaomi mi mix 3 128gb
cheap xiaomi mi band 3 smart bracelet
PIR solar sensor wall light automatic ignition by detecting people coming and shutting down automatically when the detection of people abandoned. It works up to an angle of 120 degrees and detects movement up to 3 meters away. With the solar panel, you can convert solar energy into electricity, there is no need for external power, energy efficiency and environmental protection. IP65 waterproof grade, perfect for the garden, patio, balcony, etc.
Product Features:
● Polycrystal solar panel, high efficiency up to 17%, no wiring required, intelligent energy saving.
● High quality ABS lamp body, high temperature resistance, anti-corrosion, IP65 waterproof, damp-proof.
● Easy to install and easy to maintain.
● Import Epistar SMD2835 chip, high brightness, long lifespan.
● Detects movement within 10-26 feet and 120 degrees of angle.
● Integrated design of PIR motion sensor and light sensor, high sensitivity.
● Recharged by sunlight and battery storage power.
● Auto charging in the sunlight, perfect charging time of 6-8 hours.
● Auto turn on the dim light mode at night.
● When people close, auto turn on bright light and continue 30 seconds. When people gone, auto turn on dim light mode again to save power.
● More than 12 hours of lighting time after a light day of charging.
Install it in any place you want where is full of sunshine, the simple fashion design, not only is a motion sensor, light control lamp, but also an ornament: https://gearvita.com/pir-motion-sensor-wall-light-20-led-solar-powered-waterproof-garden-lamp.html
You may also like:
cheap xiaomi 70mai dash cam pro
cheap xiaomi mi band 3 global version
ASUS RT-AC66U B1 wireless router is a AC dual band gigabit WiFi router, which can deliver WiFi speed up to 1750Mbps with 1300Mbps on 5GHz and 450Mbps on 2.4GHz simultaneously. The three high-performance antennas and four gigabit ports ensure high signal stability for both WiFi and wired connections. Coupled with ASUS AiRadar technology for expanded wireless coverage and ASUSWRT that makes setup easy, offers a robust feature set of networking customization settings, the ASUS RT-AC66U is the pioneering router to elevate your Internet surfing experience.
Product Features:
● 5th generation 802.11ac chipset delivers concurrent dual-band 2.4GHz/5GHz for up to super-fast 1.75Gbps.
● Three external antennas for enhanced signal reception.
● AiRadar optimizes wireless coverage to deliver fast and stable wireless signal for all connected devices.
● File sharing, printer sharing, and 3G/4G sharing via two multi-functional integrated USB 3.0 and 2.0 ports.
● Monitor and manage your network with ease from your mobile device using the intuitive ASUS Router App
● Effortless 3-step installation process and a wealth of robust advanced options with ASUSWRT web-based interface.
● With the ASUS Router App to manage ASUS router, from initial setup to real-time network traffic monitoring to managing security settings and connected devices.
● ASUS AiCloud 2.0 service: access, stream, share, sync, all on the go with unlimited storage expansion.
● AiProtection powered by Trend Micro provides multi-stage protection from vulnerability detection to protecting sensitive data.
● The design chassis is VESA wall mountable to place it behind monitors and other areas.
The RT-AC66U offers smooth lag-resistant multitasking and super-fast streaming. Whether you're a tech-savvy enthusiast or a first-time user, it is exceptionally easy to use, lets you plug-n-surf right out of the box and connect PCs, smartphones, tablets, and other wireless devices quickly. Thanks to its refined interface tools, you get control like never before, letting you monitor signal strength, setup parental settings, and other useful functions in a robust yet intuitive way: https://gearvita.com/asus-rt-ac66u-b1-wireless-router.html
You may also like:
cheap samsung evo plus micro sd card
cheap raspberry pi 3 model a+ motherboard
