- Jun 2, 2006
Okay, first of all, I cannot have a 2,000 pound Bridgeport mill in my shop/garage. It's not going to happen no matter the cost, no matter how much better it might be. I know it will be....doesn't matter.
Now, I basically have been saving my pennies for a while now and I would like a new TOY....and I would like a milling machine. There are certain things I believe a milling machine can do that I know would be useful to me. I can do them all now with what I have, but having a milling machine might (hence the query) make them all easier and more precise.
What I want a milling machine for:
First, I make a handle style similar to how the Japanese traditional knives are designed. Kind of like a mortise and tenon. I've attached a simple illustration picture I made. Being able to make this mortise and tenon a little more precisely and quickly would be great. Now it's saw's, sandpaper, filing guide, drill press, etc. Recently I've been using a milling bit in my old table top drill press and it's helped a lot. Having an actual milling machine would seemingly make it a lot easier still.
Second, milling down handle scales so they are even on both sides. Today this is done with a bandsaw and either sandpaper on a surface plate or belt grinder. It's not very precise and isn't a huge deal, but I figure if I start with perfectly even scales, I'm more likely to end up with even handles easier.
Third, milling slots in scales for hidden tang knives. PITA to do now....and I really don't do them for this reason.
Fourth, milling metal parts for handles. I simply don't do these now either and would like to be able to. I would like to be able to make brass/copper/stainless fitting for the aforementioned Japanese style handles.
Fifth, I eventually want to try my hand at making some folding knives.....and I believe a milling machine would be nice to have if/when I ever do. However, I don't know the specifics here so....
I believe all of the above can be done fairly well with one of the mini mills (perhaps minus the folder stuff) from various places like this one:
http://www.grizzly.com/products/Mini-Milling-Machine/G8689
I know it wouldn't be as good as a Bridgeport, but I believe it would work well enough for my hobbyist use at the above tasks.
Now, kind of the reason for the query more than anything else. Past that mill, there are mills like these:
http://www.grizzly.com/products/Mill-Drill/G0463
http://www.grizzly.com/products/2-HP-Mill-Drill/G1006
Twice as expensive, four times the weight and generally more heavy duty.
With one of these machines I'm sure the above tasks would be even easier and whatnot, but what I'm wondering if stepping up to one of these machines would allow me to:
1. Surface grind a 2" x 12" piece of 1/8" down to 0.10"? I know a surface grinder would be better at doing this, but I'm just wondering if one of these mills would work in a hobbyist scenario where time isn't a HUGE deal.
2. Taper a tang
3. Put the initial distal taper on a 8" long, 2" wide blade? Annealed and hardened?
From some internet searches and reading a few PM threads, one can surface grind with a mill using a fly cutter. My question is more can it be done with these machines when I don't have a Bridgeport monster. If not, I question my need to spend the additional money.
2. Taper a tang
