- Oct 21, 2019
I have recently started to learn the forging process and have successfully forged a couple blades, made some san mai, and have been hammering on a billet of 15N20/1095 for MANY hours to make my first Damascus blade. Like any normal sane person thinks when hammering away.... There has to be an easier way.... Hence forge press questions...
Now I know the general consensus is buy once cry once, build a dedicated forge press of ample speed and force, mini presses are a waste of time and money for any real forging, etc... While I agree in the grand scheme of things, unfortunately it's just not in the budget at this time. One day, it will be but for the time being I am looking for something that will be sufficient enough to do small projects. I'm not looking at forging Damascus swords, large billets, but rather just enough to make smaller kitchen and hunting blades while learning the process and not killing my shoulder.
It seems in my research there seems to be two camps...
First off, the Air/Hydraulic 20 Ton Mini-Press build. Seems easy enough. (I am a Mechanical Engineer by day with access to the correct tools so welding/designing a press with a significant safety factor is no problem for me.) The drawback to this design is the speed of the unit. The bottle jack only performs at a snails pace, and requires a lot of air. I have a 120gal compressor so I'm not worried about air consumption being a bottle neck. But only being able to get a few squishes per heat still takes a lot of time to forge billets.
The second camp is people taking a 6-8 ton electric log splitter and revamping it to squish steel. This is a lot easier of a build, but it sacrifices force for a bit of speed.
The question is/are, for those of you out there using one of these two methods, how does it perform? Are you happy with the performance overall? Everything else aside, Is it better to have speed or force if you have to choose one or the other? Other opinions as to which method is better for the intended purpose?
I am in no way under the illusion that either method is the best for the job, they are simply a bridge tool until I can gather the parts for a big boy press, or have the cash to buy a commercially available unit.
