- Oct 17, 2010
Hey guys, figure someone here will have some advice; I'm looking for some smaller sized, pneumatic couplers/quick connect type fittings, for my workbench, and I'm unsure what the options are.
I've got 3/8" and 1/2" standard type quick connects all around the shop, and at my bench I've got a manifold with a couple of 3/8" standard style connectors, and a couple of push-to-connect connectors for .170" (or whatever is standard) OD hose, with plugs in them.
I use a fair number of small tools, pencil grinder, air nozzles, die grinder, etc right there, and I'm trying to make the setup more convenient.
Problem is, the larger 3/8" style are big, and often very heavy on the end of the small OD hoses on say, a pencil grinder, and kind of cumbersome to attach, especially if I attach 3/8" hose to anything to get some length for one side of the bench or another.
The small tubing with the push-to-connects is great, but you have to remove a plug, push in the tubing, and keep track of the plug without losing it, because they don't seal by themselves.
I'm wondering if any of you that use more of these things than I do, are aware of any micro/mini quick connect system that works well either with the small nylon tubing, or 1/4" hose, but preferably has easy options for connecting to 3/8" npt threaded connectors or bases on most pneumatic tools?
Or are there any push-to-connect type fittings that are sealed without something seated in them?
Thanks, I'm doing research online now, but there's so many different types of pneumatic parts and fittings, and seemingly variable nomenclature for all of it, it's difficult to find anything via google.
I have found some "mini" sized quick connects similar to the larger ones, but I'm uncertain which are actually better, as there's not much info on the few different types offered by this or that company.
Cheers!
Cheers!
