Miracle Blade
SUPERIOR EDGE DESIGN:
The unique convex serration design and thin blades make the most efficient slicers I have ever encountered. The thin blade reduces drag, and I don't find the associated flexion to be problematic. The narrow edge angle greatly increases cutting efficiency, making a 'scary sharp' blade.
The key feature is the unique convex serrations which further increase the mechanical advantage and cutting power. During slicing, the serrations contact the material at an angle, increasing mechanical advantage and cutting power. This is enhanced by the overall curve of the blade. Typical concave serrations have similar advantages, but protrude and produce excessive drag. Moreover their relatively close proximity often fails to allow them to sink deeply into the material. Miracle blades' broadly-spaced serrations sharped on both sides avoid both disadvantages, slicing deeply and gliding through even tough materials. Watch you fingers!
I've found the slicing efficiency to be far superior to several other serrated and plain-edged blades. After cutting plenty of food items, I moved to woodcarving. I was astonished to find that each slice with miracle blade removed more than twice as much wood as most other knives, with less effort and more control! As a knife aficionado, I've never seen its like.
One additional design note- I imagine the sensationalist chef has already thoroughly discussed the advantages of the rocking, curved blade and the ergonomic, upraised and angled handles. I agree.
REASONABLE WEAR:
This set had used and abused for over 8 years and dulled to near uselessness before I restored a razor edge to each knife with a Spyderco Sharpmaker (using a 9 - 12.5 degree angle each side). A near-perfect regrind of the serrations was possible with a file. Others may settle with a normal, flat, stone grind, losing a little convexity, but retaining much of the convexity. Quality sharpening steels or ceramics rods would work reasonably well, especially on a reasonably regular quick-hone basis. Dulling occurs by many mechanisms, but in kitchen use the chief culprit is typically deformation and edge rolling cause by chopping on hard (non-wooden) surfaces. The convex serrations are more vulnerable to dulling than a plain edge, but acceptable. Except for the rock and chop, THESE ARE SLICERS, and if used appropriately can retain their edge for years!
There are many grades of stainless steel with a trade-off between edge retention and corrosion resistance. By way of over-simplification, the higher the carbon content, the more the blade can be hardened to resist wear and edge rolling, the lower the chromium content, and the more tendency to rust. So it is possible that cutting lemons and hot dishwashers could produce some rust or darkening, but this set showed none after years in the dishwasher. I'd estimate the hardness at 57-59 Hrc, sufficient to maintain the narrow edge angle without excessive wear. Could the 'Japanese steel' be AUS 8A stainless, a decent steel?
OVERALL:
In my opinion, a product that outperforms all competition with one function (slicing), does well in other categories (pricing $20 for 11 piece set, wear, rock and chop, ergonomics, corrosion resistance, appearance), and is acceptable one category (resharpenability) deserves five stars.
I would be interested in commentary about convex serrations and other favorite kitchen cutlery.
$20 for an 11 piece set?
Wow!
Outstanding value...
Pray tell, where can one get these "miracle" blades?
:rolleyes:
Let's not be so quick to call a new guy a spammer. The knives may not be the fanciest but he wrote a legitimate review based on his experience, no spam involved, no deal-spotting, just talking about the knives.
Good review.
One Amazon reviewer states 52 Hrc from the user's manual. That's lower than I would have guessed from my experience with both sharpening and wear. After completing the woodcarving project, the edge was still razor sharp and shavable.
The average amazon review is 3.5 stars, with the key complaints being customer service--buy a new set for $20, don't mess with their CS--and rust when cleaned in the dishwasher, which was not evident in this 8 year old set.
Is it possible that they are using lower quality steel now than when this set was purchased years ago? If not, then I see no cause for concern, based on excellent performance.
That's okay. I'm the one who wrote it and posted it both places, with a couple of edits.
Let me clarify that my primary purpose in posting here is to discuss the unique convex serrations, which I've found to be remarkably effective even in a lower-cost knife. Incidentally the serrations are and over 1/4 in long and therefore do not look excessively pronounced. Has anyone seen them elsewhere? Feedback on serration design?
I haven't even seen them here. I have no idea what you mean by "convex serrations".
Save your money for a real knife. I worked with a professional chef... who is now a personal chef for Jermaine O'Neal and loved the Miracle Blade. I used it one. It's a fancy shaped serrated knife. It's saw just like a Ginzu. It'll tear though anything you want. But your produce will bruise, you hands will callas, and your friends will make fun of you. Friends don't let friends use Miracle Blades. My brother and I went in together and got him a 8" Kershaw Shun Chef Knife. He is forever in our debt.
That's right. What you need to realize is that you don't need a full set of anything to run a home kitchen. A utility or paring knife, a medium blade for most slicing and dicing, and a large carver. Get a good knife in each size, they don't need to be from any one company, all with the same handle shape. Get what works for that size and task.
