Cobalt
Platinum Member
- Dec 23, 1998
As you all know, titanium is an extremely advanced alloy which has been adopted from the aerospace industry and into the knife industry.
Almost two years ago a purchased a couple of titanium knives, one being the Folder(MPF), the other being the Fixed blade version(MPK).
The MPF folder sat in my safe for a year before I even started using it. When I took it out, it went on a trip to Hawaii to me. I was absolutely amazed at how this knife did not change appearence even after 4 diving excursions. It still cut incredibly well with an edge that last as long as my gerber ATS-34 ez-out, but not as well as my ATS benchmade or Spyderco knives. This says a lot for titanium, an alloy noted more for it's memory and corrosion resistance than hardness. The blade is at least 5/32 inch thick, which I like since I prefer thicker blades. The overall feel of the knife is incredibly solid with no play whatsoever. A few times, I could have sworn I scratched it, but I find no evidence of scratches so it must have been my imagination. I dropped the knife onto the cement open and of course it fell tip first. There was some dulling of the point which I quickly fixed with my diafold. Overall a knife worth the money.
I have not used the MPK fixed blade knife as much, but for those who want a sturdy knife(the blade appears to be over a 1/4 inch thick) that weighs less than a knife half it's size, this is it.
Now back to titanium, the stuff they use for their blade material is Beta alloy. The main difference between Beta Ti. and pure Ti is the addition of around 13% Vanadium, 11% Chromium and 3% Aluminum. For example, the common 6AL4V is an Alpha-Beta Titanium having 6% Aluminum, 4% Vanadium. This alloy is no were near as strong as the Beta Titanium but strong enough for it's use and to make knife liners and handles. Heat treating can of course improve the Ti and some makers make blades out of this stuff. Titanium Beta alloys are some of the strongest Titaniums out there. Tensile strength is on the order of 187,000 psi, which compares favorable when you consider that 1095 steel has a tensile strength in the range of 110,000 psi to 186,000 psi. Of course alloy steels and even alloy titaniums will vary and can be higher. Hardness is uually were titaniums loose out to the hardest steels. This is all a matter of what type of alloys you use as well as the heat treatment process. Not all ATS-34 blades are created equall and neither are all Beta titaniums. Rockwell hardness tests don't do the titaniums justice since it is not indicative of the actuall edge holding. I'm sure that if I rockwelled(b) the mpf titanium blade it would not even reach 50, but it can hold an edge better than my ez-out ats-34 blade with a rockwell near 57. This should be no surprise as CPM 440V can outlast the best ATS-34 blades and has an average Rockwell of 56. The alloying and heattreat/quench process makes the difference.
Hope this helps,
Hope this helps,
