- Jun 27, 2010
If I'm trying to fill gaps between different stabilized woods, would it be safe to mix a good amount of fine saw dust from the lighter wood with some gorilla glue, and use that mixture to bond the two pieces together?
Basically is that bond going to be solid enough, and will the color match? It's stabilized white holly, and there's virtually no grains.
The way I have it set up, is a rivet will be going through both pieces, so that will hold them as well, the gorilla glue/dust mixture is more or less just being used for filler so the lines look cleaner...if it will work, that is.
