- Aug 19, 2011
vise2 1/2x4" aluminum plates
1/8" x 12" x 1" aluminum flat bar
drill
jb wield
square
sharpie/ scribe
chamfer bet
drill bet (to pre drill oles for screws)
3 flat head self tapping mettle screws
screw driver
4 screws the same diameter but 1/4" as those use to hold the plates in side the jaws. as that you will be adding a thicker plate you will need longer screws
2 clamps (open 4.5" or greater)
measure from the top of the threads to the bottom of the plate (subtract about a 1/4")
remove the plate from the inside of both jaws and save the plates
use the measurement form the threads to the bottom of the original plate (- 1/4" ) to mark wear the aluminum plate should mount to the vice. mark the side that will face down (toured the thirds of the vice that is now the bottom
tape the two aluminum plate together and use a few drop of instacure (supper glue) to attach the old plat to the new so that is can be used as a drill guid
drill
jb wield
square
sharpie/ scribe
chamfer bet
screw driver
