- Jul 11, 2010
This may get bumped back to general knife discussion, however the question is more related to bushcrafting...
I have a few Mora knives and have seen videos of people batoning (word?) small to medium sized wooden boughs on the www-- chopping as well as splitting. I use my Becker BK2 for this activity, and seeing that the knife is designed with this purpose in mind, it performs admirably. Even though the Moras are not designed for this particular activity, I'm sure some of you have at least tried it with them. The Moras I have (911 Carbon, 731 Carbon and Frosts Clipper stainless) are all amazingly sharp, fairly thick (all are .098 but for the Clipper which is .079) but they all have the modern Mora rubber wrapped plastic handles and none have a full, thick tang. I don't as of yet have any Moras with the traditional wood handle.
1. Has anyone here used any of the Mora models I have (or any other Moras) to chop or split wood by using the baton method where the eventual result was a broken plastic handle?
2. Has anyone here used any Moras with the traditional wooden handle to chop or split wood by using the baton method where the eventual result was a split wooden handle?
3. With these questions in mind, which design is more durable for batoning, plastic handle or wood handle?
(I personally would rather have neither a wood handle or a plastic handle, but most of the Moras limit you to plastic or wood). The rubber grip on the plastic handle is great, but I suspect the plastic will not hold up well to batoning. The durability of a wood handle is great, but finished wood is very slippy (moreso when wet) and wood in general splits easily when it's cold out.
Any opinions here on this?
Cheers,
Cheers,
