- Oct 2, 2014
Morakniv have released their first (long awaited) full tang knife, the Garberg. Dedicated Morakniv users have been asking for a full tang knife, as they want a hard-use version of the much loved Companion.
The Blade and Handle Geometry:
Most knife specifications have a basic description of the blade geometry, but in this section I will be taking a more detailed look at geometry and balance.
Using a set of gauges and precision measuring equipment including a Vernier protractor, callipers, fixed radius gauges and the unique Arc Master adjustable radius gauge (the one that looks like a crossbow).
These measurements have been tabulated and are presented along with a few reference blades (8" Chef's Knife, 5.5" Santoku and the popular Fällkniven F1).
Key aspects such as the primary bevel angle, grind type, blade depth, blade thickness, length, weight are detailed, along with balance information.
The 'Balance relative to the front of the handle' tells you if the knife will feel front heavy, or if the weight is in your hand (a positive value means the weight is forward of the front of the handle). The 'Balance relative to the centre of the handle' indicates how close to a 'neutral balance' the knife has in the hand.
In the case of full convex grinds the approximate centre of the grind is used for the primary bevel angle estimate.
For the Detailed Measurements, please use the 'Read MORE' button.
(Wherever you see the 'Read MORE' marker, it indicates that the Extended Version of the review has additional content at that point. Viewing the extended version helps support further reviews, but please ensure you return to this Forum for comments and discussion.)
Explained by the Maker:
The reasons for certain design choices may not be clear when simply looking at an object, so this section is intended to give an insight into the thinking behind a design by speaking to the designer themselves.
Unfortunately I can’t always get time with the designer so will use this section to include relevant information about the knife and its designer.
This is an interview with 'Head of Production' at Morakniv, Thomas Eriksson, from IWA 2017.
The discussion includes how the factory edge is created, maintained and also includes micro-bevels and zero-grinds. It is 16 minutes long, so you might want to come back to this after reading the rest of the review.
A few more details:
Morakniv did not stop at just making the Garberg full-tang. There are two versions of the Garberg available; one with a full flap leather sheath, and the other with Morakniv's Mulit-Mount sheath system. The first to arrive at Tactical Reviews was the leather sheath.
The image on the front of the box for the leather sheath version just shows the knife. The Multi-Mount's box shows the sheathed knife.
Straight out of the box the knife is hidden by the premium quality leather flap sheath. It is obvious straight away this is a very good quality sheath.
A close-up look at the press stud shows the attention to detail with the Morakniv logo embossed around the edges.
The stitching uses a heavy duty 1mm thread, cleanly punched though the 3mm leather and the welt.
On the back, the belt loop is made of the same thick leather as the rest of the sheath.
The top of the belt loop is fixed with two rivets, and the bottom with a single rivet.
Lifting the flap shows that the main sheath is a deep/full sheath.
Author's Statement for Transparency and Disclosure
The test sample/s featured in this article have been provided for technical testing and review by the manufacturer. Test samples are retained by the reviewer following publication of the completed review for the purposes of long term testing and product comparisons.
All output figures and test results published in this review are the sole work of the reviewer, and are carried out independently and without bias. Test results are reported as found, with no embellishments or alteration. Though best endeavours are made to maintain the accuracy of test equipment, the accuracy of these results is not guaranteed and is subject to the test equipment functioning correctly.
A few more details:
