Wrapped G10 Kwaiken. $85.00 Shipped in the U.S.
his kwaiken is made from black G10 and has a right side flat chisel grind. The handle is wrapped with black and red paracord with a turkshead knot at the end. It has been soaked with resin. It comes with a red kydex sheath and the only metal on it is the hardware for the belt clip. 9 5/8in long X 1/4in thick X 7/8in wide at base of blade.
G10 Kiridashi. $65.00 Shipped in the U.S.
This kiridashi is made from black G10 and has a right side flat chisel grind. The handle is wrapped with black and red paracord. It has been soaked with resin. It comes with a carbon fiber texture Holstex sheath and the only metal on it is the hardware for the belt clip. 7 3/4in long X 1/4in thick X 7/8in wide at base of blade.
G10 Whancliffe. $45.00 shipped in the U.S.
The blade is ground with a right side chisel grind. 5 1/2in X 1/4in thick X 5/8in wide at base of blade.
Small G10 Tanto. $50.00 shipped in the U.S.
The blade is ground with a right side chisel grind. 5 7/8in X 1/4in thick X 5/8in wide at base of blade.
