- May 18, 2012
Here is a new Backpacking stove I wanted to share with everyone. I will be doing a review and some videos with it. For now just some quick info!
I purchased the MSP Core 4 Stove Heavy Titanium Set that includes at least one of every part available and Case from http://mysurvivalpack.com for $120+shipping. There are the simple standard stoves in stainless and ti for a lot less. This is good for those looking for the basic 5 panel stove! 4 walls and 1 burn plate. You can also order parts individually which helps build the stove up as you want it or buy replacements!
***If Quick Assembly is important to you read my below assembly description!!***
***KEEP IN MIND***
Going from Simple Assembly with 4 walls and a burn plate to a More parts involved Woodgas mode, ASSEMBLY GETS DIFFICULT! But With practice it gets easier! Now I can assemble it in any configuration with no problem.
Once together its solid!
This Core 4 stove is a multifunction Woodgas stove that can be used with wood, alcohol or solid fuel tabs like esbit tabs.
The SHTF Grill top is interesting that besides being a cooking grill top it has fishing Hooks, points, tools that can be popped out in an emergency survival situation to get food ect. And cook on it!
This stove is unique in that it can be used ans 3 side panels, 4 panel, rocket style or secondary combustion woodgas type stove! The only collapsable Woodgas stove I know of that folds flat!
The TLUD can hold a Trangia or Esbit Alcohol Burner and a Solid Fuel attachment is included too!
In 3 panel mode its still able to use the Trangia burner!!
Assembled it feels sturdy and really look forward to using it!
With so much options you can take only parts you need for minimum weight or take it all for max versatility!
I have the Core 4 Stove Ti model but its available in Stainless Steel too.
I burned it in every way possible and the Core 4 and 3 never stops impressing me!
Here are some specs:
1. Titanium Core 3 Stove Ultralight - 4.1oz
- One front panel, two side panels, perforated burn plate
- w/Door 4.4oz
2. Titanium Core 4 Stove Ultralight - 6.3 oz
- One front panel, three side panels, perforated burn plate.
3. Titanium Core 4 Bio-Reactor - 8.7 oz
- One front panel, three side panels, perforated burn plate, three afterburners, TLUD plate
- w/Door - 8.9 oz
4. Titanium Core 4 Bio-Reactor Unlimited - 11.6 oz
- One front panel, three side panels, perforated square burn plate, three afterburners, TLUD plate, rocket port, bottom square heat shield/griddle.
- w/Standard Core grill - 12.4 oz
If your interested in getting your own I managed to get a temperary discount on 2 stoves! Info on the stoves below!
Enter "ADB-CORE-DISCOUNT" at checkout for a nice discount!
Discounts work on these 2 stove sets below!
Core 4 Bioreactor Ultimate Ti
http://shop.mysurvivalpack.com/core-4-stove-ultimate-ti
Core 4 Bioreactor titanium
http://shop.mysurvivalpack.com/core-4-stove-titanium
Core 4 Stove Assembled in woodgas mode!
Core Stove in 3 panel mode
Simple 4 panel with grill top
Core 4 Stove With rocket port!
I meet with the maker in person and took a couple pictures!
***KEEP IN MIND***
- w/Door 4.4oz
- w/Door - 8.9 oz
