After reading several posts on this forum written by some obviously erudite gents about radiant heat and over-temp excursions, I'd like to put a muffle in my electric kiln to shield the object being heated from its glowing elements. I have a an Olympic front loading ceramic kiln that I've retrofitted with a PID control and argon injection. It's small (1/2 cubic ft) so it heats up reasonably fast; I typically use it for making plane blades, max dimensions 8" x 2-1/2" x 3/16".
The problem I see w/ making a muffle is that the kiln floor measures only 9" (deep) x 11" (wide) so if I start building a muffle out of 1-1/4" firebrick, which I understand shouldn't come closer than 1" to the elements in the side and back of the kiln, I'm going to start running out of room. Even with the blade going in on a diagonal, the thick refractory eats up available space in ahurry.
Could someone suggest another material for making a satisfactory muffle? Possibilities I've considered include kiln shelf tile or ceramic (alumina,etc) refractory tube of approx 4" diameter. Using kiln shelf material begs the question how one would hold the muffle together--drill holes for pins, or what?
I could bend a muffle from Inconel sheet; there are alloys in this family that certainly could take the degree of heat used to HT any knife steel. But what I wonder is whether such a muffle would itself glow red at HT temps--if so that might be as much of a problem as the glowing elements themselves. Or maybe Inconel 803 doesn't glow till well past 2000F?
I hope to avoid a solution that involves ceramic fiber. I know people here use it all the time for various applications. But I don't like the idea of the micron-sized fibers finding a new home in my lungs. Sure, a P100 mask would stop most of them, but what about all the fibers that land on the user's clothes, in the shop, get racked inside for the family to inhale, etc. Maybe I've gotten like Howard Hughes and germs, but I've been there, done that all the years working w/ asbestos.
Thanks very much in advance.
