I'm not a 'Jungle Jim' type, and really have no business buying a machete. But, for $6.08 (tax included), why not. Cheap toy. If you really want to irritate the hell out of your spouse, waving a machete around works perfectly!
You wouldn't expect a cheap machete to have a well-formed edge, and you'd be right. Edge is perfectly dull - about 1/16" perfectly flat/blunt edge between unevenly-formed bevels. Accidental cuts would be near-impossible.
The steel seems better than I expected. I used a mill bastard (single-cut) file that I keep for sharpening my mower-blade, and judging by resistance to filing, blade hardness was about the same as the rotary blade on my mower. Getting an initial working edge required about an hour of hand-filing.
The plastic handle slabs are hand-filling with no rough edges. Fits my medium-size hand well, providing good wrist rotational-control.
Since I have no trees to chop or acreage to clear, I used the machete to trim some pine boughs and rough-trim a 50' hedge. Using the final 6" of the blade and the high speed of the blade-tip, it did a good job of rough-trimming the hedge. The thickness of the handle slabs provided good wrist control of blade angle of attack. Precision suffered a bit due to repeated hysterical warnings by my spouse.
That's not much of a test, but there was no apparent dulling of the 6" of edge that did the actual work on 50' of hedge (English Privet). Any perceived 'dullness' was due simply to build-up of green vegetable matter from the hedge. This machete seems like excellent value. I suspect it would do nicely for heavier work, accompanied by a file in your pocket.
$6 well-spent!
$6 well-spent!
