Thanks to a few guys on this forum, I was inspired to build a much nicer high end propane burner. My first one just wasn't getting enough air, and had no adjustable air flow. So in turn, the flame just was barely getting hot enough to bring my steel to non magnetic. Not any more. This new burner gets way hotter. heres my parts list:
1 pc 3/4" sch 40 304ss pipe 9" long
1 pc 1" sch 40 304 ss pipe 2" long
1 pc 1" sch 40 304ss pipe 4" long
1 pc 1/4" sch 40 304ss pipe 8" long
2 pcs 1" X 1 1/2" sch 40 304ss concentric reducers
1 pc .045" mig welding tip (for the jet)
1 pc 1/8" 304 ss sheet cut out to cover end of concentric reducer
so I just welded one reducer to the 4" long piece of 1" 40 pipe (I did have to take the id down on the reducer a little on a lathe to get it to slip over the 3/4" pipe, but this could also be done with a grinding wheel on a dremel) and drilled a hole and tapped it with a 1/4-20 tap for a set screw.This is my nozzle. Then I slipped the 2" long piece over the 3/4" pipe and brought the ends flush and welded it in place. I then welded the other concentric reducer to the end of that 1" pipe. Then I drilled a 9/16" hole all the way through the end of that concentric reducer. I then took the 1/4" pipe, threaded one end and welded the other end shut. I then drilled and tapped a 1/4-28 hole into it about 2" from the end for the jet. I shortened the mig tip so that I could slip the 1/4" pipe through the 9/16" holes, then thread the mig tip into the 1/4" pipe, and spin it 180 degrees so it pointed down the 3/4" pipe. Then I welded the 1/4" pipe in position so the jet was pointing directly down the center. The I welded a small tab with a 1/4-20 tap in it onto the intake side and put the plate on for adjusting the air intake and VOILA. All done. Here is the finished result. Let me know what you guys think. It burns excellent, with tons of adjustability.
