Thanks for the kind words.Glad you like the Code 4. I like mine . It carries very small for its size. Feels good in hand.
Btw, you did a nice review.
Cops seem to take in a lot of factors pretty fast. I wouldn't want "Broken Skull" you be one of those factors.
For the same reason, I don't wear Joe Rocket motorcycle gear. ;-)
I wish Cold Steel would make a G10 handled version of the Code 4.
This backlock with heavy blade and no detent is good at doing the following
I can do it with other knives, but this one is the easiest and you can do it very short and it looks like just wrist.
I learned this one after understanding how to do it with just holding it with your fingers.I've been using that inertia opening for over 20 years. Even taught it to quite a few people because of its economy of motion, and when done correctly, minimum amount of space required ... it can be done almost belly to belly with no telegraphing the movement if the closed knife is already in your hand. When first learning it, hold the knife between your fingers with your palm down, then while anchoring the knife's pivot on or near your centerline, rotate the handle around the pivot to the palm up position with a snap. Palm down to palm up, with the pivot anchored in space. It's a good one to know and easy to do with proper practice.
Its cool because you transfer the force into it in a way that is similar to cracking of a whip. You gotta have a certain level of relaxation for it so that the kinetic chain works properly. Tension doesn't help you much here.
The exaggerated elbow I showed is to help with the learning process, but also when you take folder out of pocket the elbow is already in this cocked position and by dropping it down you can potentially generate more force to reliably open under possible stress and whatnot.
Neato ! Beyond my skills , but I like it . I mostly just avoid non-grippy handles , because my mods ain't so pretty .Well you could do this. A bit weird I guess. I added a thin G-10 overlay and then textured for improved grip. It's glued with G Flex epoxy.
Nicer than my grip tape on both sides. But I still get a much better grip with no significant increase in width.Well you could do this. A bit weird I guess. I added a thin G-10 overlay and then textured for improved grip. It's glued with G Flex epoxy.
