- Jul 26, 2008
I have my own take on the artificial sinew idea. I use fine hemp or jute cord, then I rub into the fibers some waterproof white glue (Weld Bond works good) and stitch or bind together my pieces with that before it dries. It dries really hard and durable and holds itself together just like real sinew. It even looks more like real sinew than the artificial stuff. You don't even need to tie it because the glue holds it all together and when it's dry it doesn't lend itself to fraying apart like the waxed kind does. There are probably some other natural cords that would work well for this too. Just thought I'd share this idea with you guys. There are so many neat little things that can be done with just a little creativity. Anyways, thanks for looking.
One other thing that I've discovered, is that if you take the waxed type artificial sinew and with hot water wash out the wax, you can use the glue to bind it instead and it holds a lot nicer.
