So I've been at this for some 4 months now... and I have yet to get a straight razor to hair-splitting sharp. I don't consider myself a novice to sharpening in general; I can get a knife hair-splitting easily.
So my equipment has been this:
1. DMT EF for setting the bevels.
2. Spyderco UF for finishing.
3. I just got a Norton 4000/8000 (but up until now, it had only been the above two.)
I've used sharpie to see where I am grinding. I am hitting the bevels (all of the marker is removed in one pass; this should mean that the bevels are very flat and I am indeed touching the edge.) I can get the razor very sharp with the DMT EF. During the process, I can drag my finger across the stone and pick up metal. However, when I go to the Spyderco UF, the blade seems less sharp. On top of that, I can barely see any metal being deposited on the stone. This is UNLIKE when I sharpen my knives. Sharpie marker is removed from the bevels, incidentally.
So I had a weird thought that maybe the Spyderco ceramic is somehow too hard for the carbon steel. So I went out and got a Norton 4000/8000 stone. It had to be finished with sandpaper on glass before use. So I went through the motions again... DMT EF... Then Norton 4000... Then 8000.
After the 8000, the bevels seem to have a brighter shine. However, the razor is STILL not hair-splitting sharp. It's about at the same point as before when I finished with the Spyderco UF for the past few months. The razor will shave, but it's not a very comfortable shave for the face (no, I don't shave other areas; I'm just saying that it can shave arm hair, for example, but you wouldn't want to shave your face with this.)
Does anybody have ANY idea what I could possibly be doing wrong? Angle can't be a problem, since the jig is "built in." I don't think pressure could be a problem; I've tried everything from heavy to light. I've heard of people finishing their razors with these stones that I'm using, so I don't think that can be the problem. Plus, I use these same stones to get hair-splitting edges on my knives. I honestly can't think of any reason that my razors aren't splitting hair. I'm about ready to get rid of all of my straight razor equipment if I can't figure this out
