- Jan 9, 2006
I would like to share my ridiculously simple setup for shooting knives.
Not only is this cheap, easy to make, quick to setup, a pleasure to use and extremely portable it also produces fantastic results.
First you will need an A3 or larger 1/8" sheet of clear frosted perspex acrylic.
That's it!
Well....almost, you still need something to prop it up.
Couple of these wooden dowel rods should work, drill two holes in the top corners of your perspex sheet slightly smaller the the rod diameter, then taper the ends of the rods and cut to size according to the size of your sheet, you want it at about a 45° angle.
Now you could use 3 or 4 large daylight bulbs to light this thing but I have a solution that provides more light, fits in your pocket and doesn't require mains electricity to run, meaning you could set this up literally anywhere.
What I prefer to use is known as a speedlite/strobe or a flash. Yes a flash, similar to the one you have on your camera but many times more powerful, adjustable output and a totally separate portable unit.
The key to operating the flash is a wireless trigger, meaning when you press the shutter on your camera the flash fires at the exact same time all while being 10ft away and totally detached from the camera, allowing you to ditch your tripod shoot naturally and not have to worry about camera shake.
Sounds great doesn't it but your probably thinking equipment like that must be expensive, well not too long ago it was but in recent years prices have come down dramatically due to more third party manufacturers making these products.
Now this does require you have a DSLR or at least a camera with a hot shoe for external flash but you should be able to pickup an older model for a very reasonable price, lenses can be upgraded as you go.
Some prices from Amazon
Canon Digital Rebel XTi 10.1MP Digital SLR Camera (Black Body Only) $84
YONGNUO YN50mm F1.8 Standard Prime Lens $52
SanDisk Ultra 16GB Compact Flash Memory Card $16
Neewer TT560 Flash Speedlite $31
Neewer 16 Channel Wireless Remote FM Flash Speedlite Radio Trigger $23
12" x 18" - 1/8" (0.118") DP9 - Two-Sided Frosted Finish- Clear SatinMatte Finish Acrylic Sheet $12
Dowel Rod - Wood - 1/4 x 12 inches - 10 pieces $3
So for a little over $200 you can have a complete setup for shooting knives including the DSLR camera, lens and lighting equipment!
Some extra tips:
- Wrap a folded envelope around the strobe head to further diffuse the light as shown in the image above, you can also point the head upwards, note I mostly shoot with the unit on half it's power output, you'll be surprised how powerful it is.
- If you do decide to buy the above suggested camera, you can purchase a CF/SD adapter which allows to you use SD cards (much cheaper).
- The flash trigger actually comes with two receivers so if you plan on shooting larger knives you can pick up an extra flash unit to more evenly distribute the light.
- Manually set the camera shutter speed to 1/250 second to keep it in sync with the flash, keep ISO at its lowest setting and use the aperture to control the exposure, the larger the F stop number the more of the frame will be in focus.
That's it!
Some extra tips:
