Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
just a little clarification. Epoxy, such as the West System product, is one of the three common fiberglass resins used in the marine industry. The other two are polyester and vinylester. I am told that most of the time, boat builders use the other two on less stressed components because epoxy is quite pricey. But in your application, it shouldn't be an issue. With that said, my understanding is that real Micarta uses yet another phenolic based resin.
Yes, reinforcing what JDM said. what people often refer to as boatbuilding fibreglass resin is often polyester resin. cheap and basic... Epoxy resins are also used for fibreglass for boat construction and is essentially an advancement to improve on the shortcomings of polyester resin, such as UV sensitivity, water absorption and delamination. For handles you are looking at small volumes of resin so probably epoxy would be a good route anyway.
The usual objective of composites manufacture is to get a high 'fibre volume fraction', and using a press or a vacuum will help you get there, and help eliminate ugly voids
I have a question that I have been meaning to ask for a long time. Why do people want to make their own micatra? It can't be the cost. Is real micarta inferior to home made? I have not used any since the late eighties.
Also because Westinghouse et al. never saw fit to make weird things like camo pattern MicartaI have a question that I have been meaning to ask for a long time. Why do people want to make their own micatra? It can't be the cost. Is real micarta inferior to home made? I have not used any since the late eighties.
They don't have to be still. I had a very unpleasant experience with a fiberglass radio antenna on our boat that had the gel coat worn off by salt spray, etc. VERY ouchyHi Joe - I'm pondering this issue and I'm wondering if we're on the same page. The fiberlgass cloth that I've worked with in modeling is not sharp or pokey in any way. As a child and teenager I worked with it extensively without any gloves or even a respirator (not that I recommend this). From what I understand of G10, it's fiberglass cloth and melamine resin. Is the concern that when the fiberglass resin wears with use that you'll be left with stiff glass splinters on the handle?
