N690 vs S30V
I am now just waiting for my new ER fulcrum II to arrive and I was thinking how N690 compares to S30V as far as performance an ease of sharpening. Also is everyone pleased with the lock up mechanism as opposed to the integral lock?
N690 is definately easier to sharpen, I haven't used any of my S30 knives for any real work so I can't compare edge retention...........
N690 has both nickel and cobalt in it, something we don't often see in stainless steels.
Anyway, nickel has a long history in saw steels for making saws tough and resharpenable.
Up here in the Northwest woods we have tons of L6 nickel steel saws, and they make great knives that take a beating, hold an edge and sharpen easily.
S30V's big advantage comes from particle metallurgy, which allows the steel maker to keep the alloys homogenously distributed and keep the impurities out.
For those not familiar with smelting steel, the various alloys in steel all have different specific gravities, meaning, they weigh more or less for a given volume.
This means that some alloys tend to either float on top of steel or sink to the bottom, sort of like oil and water.
The steel makers in the past have attempted to get around this by constantly agitating the molten steel until the time comes to pour it into ingots.
Still, in those few seconds it takes the steel to go from liquid to glowing semi-solid, the alloys have already begun to stratify so that the steel does not have a uniform distribution of alloys all the way through.
For this reason, many metallurgists have dreamed of a future when they could mix molten metals in the zero gravity of space.
However, in today's world of super-metals, the metallurgists have learned new tricks, among them, particle metallurgy, which allows the maker to mix the allows as fine particles and then press them together under heat and pressure, without the steel ever attaining a true liquid state where the alloys would have the opportunity to stratify.
Crucible Particle Metallurgy (CPM) makes S30V using the above method.
Other makers have developed other strategies.
For example Timken-Latrobe, maker of BG-42, and Hitachi, maker of the very similar ATS-34, have developed double vacuum melts with electric arcs, in which they pour and role the highly agitated liquid metal, and keep rolling it as it cools, all in a huge vacuum facility.
Their methods produce very homogenous steels.
After all, they use BG-42 as bearing steel in the most advanced jet engines.
They have to really trust its properties.
I don't know the smelting details of N690, but given the outrageous complexity and sophistication of the alloy mixture, and knowing the reputation the Italians have with metal, I suspect they have as good a means of dealing with stratification as does Timken-Latrobe, Hitachi, or CPM (maker of S30V).
I'd like to know more about it, though, just out of curiosity.
Gee Whillickers!
After me making such a big thing about nickel steel, the ER site does not list nickel as an ingredient of N690.
I wonder where I got that idea.
I'll have research this some more.
Anyway, N690 does have cobalt in it, even more so than does VG-10.
They need a little "blushing face", like a smiley face except "whoops." :)
From a non-english site:
"The result is a blade with a very hard edge (therefore sharp and longlasting) and an elastic and though body. It is used for the production of industrial blades of high quality, installed for example on industrial meatchoppers where the holding of the edge is important (for a minor maintainance) and the stainlessness, seeing that they have to work in presence of air, water and biological acids, and the oxidation would result very polluting for treated alimentary products. It is as well used for the production of milling tools to work steel, thanks to its hardness, to which fragility is exceptionally not accompanied. Another tipical usage is the production of razorblades or bistouries for the above mentionned characteristics."
http://www.afcoltelli.it/newseng5.html
Some sources refer to N690 as a Swiss steel.
At least one manufacturer makes N690 using the Particle Metallurgy process.
http://www.cruciblecompaction.com/corrosion.html
"P/M N690 has excellent resistance for Intergranular Stress Corrosion Cracking (IGSCC) and is ideal for many applications in the marine, nuclear power, pulp and paper, chemical process industries."
In other words, they trust it in Nuclear plants because it resists cracking due to creeping internal corrosion.
Very nice.
Boehler from Austria makes N690. S690 is the steel made by pm process.
I would like to hear more about N690. What experiences are made with it by ER users? Is it tough or does it tend to chip?
