- Jan 20, 2008
I bought my Izula to be carried around my neck. As I have grown older, safety has become a bigger focus in my life. The reality is that a neck lanyard TIED with 550 paracord can easily hold someone up by their full body weight without letting go. That's not a safe solution for a lanyard encircling one's neck. However, I also want a strong lanyard which holds together securely when I yank the knife from its sheath and one that lasts for the life of the knife/sheath. The solution may be a break-away connection, to hold the ends of the lanyard together, but that requires buying a new piece of hardware and fitting it into the ends of the cord (I already have cord locks). I wanted to use 550 paracord because I have it, it is very useful for other things if needed, and it is strong.
One solution... Pull the ends of the neck lanyard through two of the holes in the Izula's sheath and place a cord lock on the ends. This allows the lanyard to be secure when the blade is yanked from the sheath, but it will still slip and let go with a strong force (maybe 30+ lbs). The problem with this setup is that the ends of the cord with the cord lock will stick out an inch or more from the sheath's body. It was noticable when I wore a single shirt layer over the sheath/lanyard. No good. That config can be seen in the picture HERE.
My new solution... As seen in the picture below - I have tied one end of the neck lanyard into a small loop, using a Bowline knot. The other end of the neck lanyard has been threaded through two holes in the sheath. I put a cord lock on the free end of the cord, looped it through the loop on the other end, and ran it back through the cord lock (see picture). This is very easily adjusted for length, it is much flatter than the last method, it is very secure holding the sheath, and it will slip and let go with a strong force (maybe 40+ lbs). I hope this helps someone who is in my position.
Note: When melting the end of the paracord which passes through the cord lock, make sure to flatten any "bulge" of melted material that would prevent the end from slipping freely through the cord lock.
ETA: My cord lock (not the one that came with any RAT knife purchase) may be different than the one you use, causing a difference in the release tension of the lanyard. It's probably a good idea, once you get your neck lanyard set up, to give the sheath itself a tough pull away from your body. Test the retention of the system yourself, to gauge how severely the lanyard will pull on your neck in the case it became caught on something.
