I am surprised that whoever manufactured this shovel did not put their name on it somewhere.
It has a beautifully shaped, forged-steel blade that is fit into a handle-forging with precision machining, forgings are welded onto each end of the tubular steel shaft to hold the blade and wood handle. The entire thing rings like a bell if you flick it with your finger, as if it is all hardened alloy steel.
It has one mark on the handle forging that may identify the company that forged that part.
It almost looks as if the shaft may have been nickel-plated at one time. Anyway it is a beautifully made old shovel that must have cost a LOT to manufacture with all the forging, welding and putting a taper into the handle-tube at the blade-end. When I get my antique wheelbarrow out to haul some gravel, this is the shovel I will use with it from now on, and it will be a pleasure. As long as it is not too hot out....
