MelancholyMutt said:
Speaking of fishing... are these any good?
Automatic spring loaded fishing thingies...
I consider myself a pretty avid fisherman, and I've never seen one of those. I can only imagine that its as good as a hand tied line. In other words, I can't see what benefit it would give you.
As for a fishing kit, all the ideas above are useful. I am taking the assumption that this is a "survival" based kit, and not a "car kit" for general use when you drive by some good water. This is what I have to add:
1. A size #25 hook is VERY small. Most lures are based on a #10 or #12 fishing hook. Some small midges go as low as #25. If you've never fished with a hook that small, trying when you are hungry looking for food is not the best time. Based on this chart:
LINK
You would be better off with a size #10 or #12. You can easily catch small bluegills with a size #10 hook and a piece of bait.
2. Pack extra everything. Its completely unreasonable to assume that 1 hook, 1 grub, 1 lure, and one length of line will catch you fish. Assuming you are using this as food or as a supplement for hunting/gathering you will need more than one fish. Even small fish will tear a plastic grub apart after 2 or 3 fish.
3. Line: Make sure you use a descent brand of line and rotate it every year. Monofilament line breaks down when in contact with the elements. This means that line you packed away 2 years ago is usually as brittle as glass. There is nothing worse than loosing dinner because you forgot to rotate the equipment. Also consider where you are planning to be. Most situations should call for no more than 8lb test. I would imagine that you would be luckier going with a 6lb line for survival fishing. (Bluegill, panfish, small trout, small bass). If you are planning on lake fishing, a larger test might be more in order. You never know what can grab your lure there.
4. Practice.. I can't stress that one enough. Fishing itself is such a basic idea but unless you have an understanding of how it works together, you will lose fish. The most difficult parts are learning what is a hit and what is a rock on the bottom, How to set the hook, and how to fight a fish (ie: drag setting, how not to pull when they jump, etc..)
Just some ideas I thought of.. Hope it helped.
