- Oct 18, 2001
This thread is getting kinda long...so I'm going to post the sheath pic in its own thread. I'll still update this thread as I make changes/upgrades/etc to the design. Thanks for lookin!
Rafael...I have handled the koster WSK and I can attest to it's handling abilities...There is plenty of room on the handle for normal use without using the fingerhole...And if you decide to twirl it using the fingerhole, you WILL tend to nick you hand a bit...
Suggestion: why not radius the finger holes to remove the sharp edges?
n2s
Thanks for the comments guys! :thumbup:
I had some time today to do a kydex combo sheath and here are the results. Let me know what you think!
With the help of the "KydExpert" Tom Krein...I figured out a way to set it up so that each sheath can stand on its own as well as be tethered together.
The larger sheath has the proper rivets for horizontal and vertical carry - as well as canted (two different angles - steepest shown in pic).
The smaller sheath is set up to use the In-The-Waistband TekLok on the top, or regular size on the bottom (for horizontal or vertical carry).
When tethered together, the whole package is only 1" thick (from front to back including handles) and weighs 29 ounces - including the TekLok.
Anybody have the overall sheathed weight for a 15" BAS for comparison?
It was tricky at first trying to get the top sheath mounted in a way that would allow it to be drawn on its own - but now it's solved.
