Greetings,
I need some advice regarding surface grinding.
I have a good friend who offered to surface grind a few blades for me. He has access to a big surface grinder with a stone wheel at work.
Now to give some context: my surface grinding up until now consisted of a lot of hand sanding on a granite surface plate with sandpaper. I was able to do it, but man was it always a pain in the butt.
So my question is this: how diligent are you to make sure your steel is as straight as possible before your surface grind it?
I am asking because my understanding is that, if you slap a piece of steel that has a slight bend to it on a magnetic table of a surface grinder, the magnetic table will just straighten the piece out when you turn it on. Then your surface grind and get your stock nice and flat and parallel and then if you take the piece off the table again the bend is still there. (Please correct me if my assumption on this is not correct!)
Also I would be grateful for any good tips and tricks you use to straighten your steel, especially how you deal with a twist in your stock.
Note: this is all talking PRE-heat treat!
Best regards
Best regards
